Is there a way to make HTML Editor by default make text in to paragraphs
Thread begun 4/28/2023 8:54 am by BillHobbs | Last modified 5/01/2023 10:02 am by Ray Borduin | 1028 views | 3 replies |
BillHobbs
I'm using CKEditor 4 I think.
I've created a form where my client can enter text that they can update. I've used the simple wysiwyg features for the client to enter the text. Typically it will just be 5 or 6 paragraphs of text.
Currently when they enter text it doesn't put it in the <p></p> tags. It just adds </ br> instead of making text paragraph blocks. Is there a setting to make paragraphs the default setting?
Yes. You can update the settings .js file to make it use <p> tags instead of <br>.
In the file: webassist/ckeditor/config.js just remove the lines:
config.enterMode = CKEDITOR.ENTER_BR;
and:
config.autoParagraph = false;
BillHobbs
Perfect, thanks.
PatriceWebAssist
Thanks for this! I've been trying work arounds for a long time with this issue.
