Can no longer login in after moving hosting companies
Thread begun 5/16/2023 2:42 am by georgina_barrett_187762 | Last modified 5/23/2023 6:02 am by Ray Borduin | 1921 views | 6 replies |
I have just moved hosting companies and everything else seems to work except the login authentication. The login redirects successfully but when it goes to the next page the Restrict access code logs you back out again. This is the login user code:..
<?php require_once('../Connections/georgeconnect_i.php'); ?>
<?php require_once('../webassist/mysqli/authentication.php'); ?>
<?php require_once('../webassist/mysqli/queryobj.php'); ?>
$Authenticate = new WA_MySQLi_Auth($georgeconnect_i);
$Authenticate->Action = "authenticate";
$Authenticate->Trigger = (isset($_POST["Submit"]) || isset($_POST["Submit_x"]));
$Authenticate->Name = "DatabaseLogin";
$Authenticate->Table = "login";
$Authenticate->addFilter("username", "=", "s", "".((isset($_POST["username"]))?$_POST["username"]:"") ."");
$Authenticate->addFilter("password", "=", "s", "".((isset($_POST["password"]))?$_POST["password"]:"") ."");
$Authenticate->addFilter("Company", "=", "s", "Ascars");
$Authenticate->RememberMe = (false);
$Authenticate->SaveLogin = (false);
$Authenticate->AutoReturn = false;
$SuccessRedirect = "home.php";
$FailedRedirect = "index.php";
if (function_exists("rel2abs")) $SuccessRedirect = $SuccessRedirect?rel2abs($SuccessRedirect,dirname(__FILE__)):"";
if (function_exists("rel2abs")) $FailedRedirect = $FailedRedirect?rel2abs($FailedRedirect,dirname(__FILE__)):"";
$Authenticate->SuccessRedirect = $SuccessRedirect;
$Authenticate->FailRedirect = $FailedRedirect;
$Authenticate->execute();
And this is the code on the redirected page....
<?php require_once('../webassist/mysqli/rsobj.php'); ?>
if ("" === "") {
$RestrictAccess = new WA_MySQLi_Auth();
$RestrictAccess->Action = "restrict";
$RestrictAccess->Name = "DatabaseLogin";
$RestricAccessRedirect = "../index.php";
if (function_exists("rel2abs")) $RestricAccessRedirect = $RestricAccessRedirect?rel2abs($RestricAccessRedirect,dirname(__FILE__)):"";
$RestrictAccess->FailRedirect = $RestricAccessRedirect;
$RestrictAccess->execute();
The code looks good to me. I'd probably need FTP access and a URL to reproduce this to debug it and see what is going on. Most likely your Session variables aren't working on the server. That is usually an issue with the session_save_path in the php.ini pointing to a non-existent directory.
I think this might be the case because I have just experienced another error when using InsertQuery. I have 2 inserts on one page and the second insert uses the saveInSession from the first query, but when I submit the form I am getting this error..
Warning: Undefined array key "ContractID" in ....
It is a server configuration issue.... most likely bad session.save_path. I uploaded this file to show the issue:
https://www.alicanteairportcarparking.com/session_check.php
If you give that to your hosting company, once that page says "sessions work" the issue has been resolved.
Thank you. I have contacted my hosting company and if I follow the link https://www.alicanteairportcarparking.com/session_check.php it says... working
save path exists
However I am still getting the same problems as before. I still can't log in. The login script works and takes me to the next page but the $RestrictAccess code on that page kicks me out again. Also I am still getting the Warning: Undefined array key on the multiple insert page
Can I get FTP access to the parkingascars.com site and get the username and password to test with? I'll test to see what might be wrong.
Thank you, I spent all day yesterday trying to resolve this issue with Hostgator. They just kept insisting that the error was in the coding and because of that there is nothing they can do.
I even copied a basic session script from this page https://www.php.net/manual/en/function.session-start.php, (https://www.parkingascars.com/page1.php) which didn't work and they still insisted the error was with that coding as well - unbelievable.
I have received an email today from support - again saying that the error is in the code and there is nothing they can do, yet I have just tried to log in again and it is all working, and the script on this page now works (https://www.parkingascars.com/page1.php. Maybe they didn't want to admit it was their fault - or something they did in testing fixed it without them knowing - but at least it is all working now. I have to say I wish I hadn't moved to Hostgator and wouldn't recommend them.
