There is an error in your SQL syntax.
Thread begun 6/30/2023 6:01 am by birdscreen398247 | Last modified 7/05/2023 11:03 am by Ray Borduin | 572 views | 1 replies |
birdscreen398247
When I click on Submit in the attached file, I get "There is an error in your SQL syntax."
And no changes are saved.
I cannot find the syntax error.
Can you find it?
If you turn on the ->Debug setting in your rsobj.php and queryobj.php file it will give you the actual error that points to the problem. That should allow you to fix it. You should turn debug off again before going live because it can reveal things like database and column names or even database usernames you don't want easily discovered by a potential hacker.
