I need help with accents in text.
Thread begun 7/07/2023 7:40 am by Mike | Last modified 7/30/2023 7:06 am by Ray Borduin | 1350 views | 4 replies |
Mike
A client of mine just changed hosting, but now I'm having problems with accented texts; for example, if there is "umidità" in the text in the database table, it shows up as "umiditÃ" on the website, and so for all other accents.
On the database configuration file is set: $MyConn->set_charset('utf8');
On the previous hosting, everything worked correctly but not anymore.
I noticed that the encoding of the tables in the database is switched from the previous one:
Default Character Set: utf8
Default Collation: utf8_general_ci
To this new encoding:
Default Character Set: utf8mb3
Default Collation: utf8mb3_general_ci
For your knowledge, I have applied to the file "rsobj.php" what is reported in this ticket ($this->Prepared = false;):
https://www.webassist.com/forums/posts.php?id=41498
However, accents did not work even before with "true."
Any ideas on how to solve this problem?
Thank you.
Prepared statement setting wouldn't effect the character display.
Character displays depend on three areas being in sync. The charset in the database column, the charset in the connection file, and the charset on the page itself in the html. If they don't match, then you can have character encoding issues. Make sure you have the charset correctly set in all 3 places.
I'd try changing the encoding back to the original value in the database. The utf8mb3 could be the issue.
Mike
The problem is that I can't find utf8 in the character set.
I have these options available:
armscii8
ascii
big5
binary
cp850
cp852
cp866
cp932
cp1250
cp1251
cp1256
cp1257
dec8
eucjpms
euckr
gb2312
gb18030
gbk
geostd8
greek
hebrew
hp8
keybcs2
koi8r
koi8u
latin1
latin2
latin5
latin7
macce
macroman
sjis
swe7
tis620
ucs2
ujis
utf8mb3
utf8mb4
utf16
utf16le
utf32
All the pages have this:
<meta charset="UTF-8">
Any alternative ideas? Is there anything I could ask the hosting provider?
Mike
Fixed. The issue was with the database export tool (Navicat). I've changed the tool (PhpMyAdmin), and the accents render on the website well.
Thanks for updating the thread with your solution to help others that might run into the same problem.
