Fatal error: Array and string offset access syntax with curly braces is no longer supported
Thread begun 7/14/2023 9:08 am by cal114936 | Last modified 7/30/2023 7:17 am by Ray Borduin | 158 views | 1 replies |
cal114936Beta Tester
I'm getting an error.
Fatal error: Array and string offset access syntax with curly braces is no longer supported in /home/dirttrac/public_html/webassist/mysqli/rsobj.php on line 143
I reinstalled extensions etc. Same error.
After reinstalling, make sure to update the recordset to force the rsobj.php file to be updated and then upload it to the server. I'm sure that file has been updated to fix your issue.
