Shipping charges between two amounts ie... 10.00-25.00 add $5.00 flat rate.
Thread begun 7/17/2023 10:38 am by Supreme Geek | Last modified 9/08/2023 6:16 pm by Supreme Geek | 1495 views | 5 replies |
Supreme Geek
Hey Ray,
I have a shipping rate chart that I want to implement into the shipping charges.
$10.00 to $25.00 the rate is $5.00.
$25.01 t0 $60.00 the rate is $10.00.
$60.01 to $150.00 the rate is $15.00.
Over $150.00 the rate is $20.00.
I have attached a screen shot of what I believe to be correct for the $10.00-$25.00 charge under the "Shipping" tab. Is this correct?
Thanks for your help Brother!
All the best,
Dale
No... trigger should be "based on cart total"
and charge should be "flat rate"
What is the charge for 0-$10
I'll help but I need to know if there is a 0-10 charge
Supreme Geek
Hey Ray,
There is no charge for the $0-$10.00 category because you helped me make it so the order won't go through unless they buy at least $10.00 of merchandise. Thanks for your help Brother! Have a nice day, eh?
All the best,
Dale
ok...
There are more ways to do this than one, but here is one using 4 rules....
Rule 1:
"Based on cart subtotal" >=10
"Flat Rate" 5
Rule 2:
"Based on cart subtotal" > 25
"Flat Rate" 5
Rule 3:
"Based on cart subtotal" > 60
"Flat Rate" 5
Rule 4:
"Based on cart subtotal" > 150
"Flat Rate" 5
Supreme Geek
Thanks Ray!
I gave it a go. Now it works awesome!
All the best,
Dale Iannello
Supreme Geek
All fixed....Thanks Ray!
