shipping not adding on to checkout
Thread begun 7/26/2023 9:10 am by NWak04030229 | Last modified 9/02/2023 5:05 am by NWak04030229 | 3081 views | 11 replies |
NWak04030229
My shipping doesn't appear to be adding on to the cart after 'State' selected in checkout. I am using Total Items as my formula for calculating the shipping. I have attached what the other sites look like but on the one I am working on there is no Order Confirmation at the bottom of the screen with shipping, etc. I have a feeling it is something to do with my previous post where the line of code was showing up as incorrect but can't figure out what it is - really appreciate any help on this as needing to get website up and running Thanks
Can you provide FTP access? I'll have to look at your checkout page and cart object code to find the problem.
NWak04030229
hope this is what you need
Unfortunately that ftp information isn't working for me. Please test it for typos and make sure there are no IP address restrictions keeping me out.
NWak04030229
See PM
I got in.
In your shipping rules instead of using:
$_SESSION['eCartCheckoutForm_shipping_state']
try using:
$_SESSION["WASF_CheckoutWizard_NewFromBlank_Default"]["Country_2"]
The new ecart checkout uses different session variables.
You could also use:
WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Country_2')
NWak04030229
I did that - I replaced them in the weebooks_PHP.php. But the shipping still doesn't show up I'm afraid. When I put in the second one above - I get an error logging on to site on line 89:
if (true && ((sizeof($this->Items) == 1) && (isset(WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Country_2'))) && ((isset(WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Country_2'))?WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Country_2'):"") != "EU") && ((isset(WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Country_2'))?WA_getSavedFormValue('CheckoutWizard_NewFromBlank_Default','Country_2'):"") != "GB"))) {
Use this syntax:
The other one uses a function that may not be defined on all pages the cart is on, so that is probably the source of errors.
If it doesn't work, attach a copy of your cart .php page so I can see the code in place.
NWak04030229
Did that and I can now get into the shopping cart but still no shipping prices coming up. Have attached cart.php
Is there a url I can use to test and see the issue? That will allow me to debug. Also include the address you are using, what you have in the cart, and the charge you would expect to see.
