Do we have a tutorial available that walks through role based logins using SA and MySQLi? If not, I will need help setting it up.
Thread begun 8/03/2023 8:47 am by Richelle | Last modified 8/08/2023 6:49 am by Richelle | 857 views | 2 replies |
Richelle
I have a website where I need specific aspects in the admin area based on their role.
So SuperAdmins and Admins can see and manage everything
Managers can't edit users
Limited can only access select parts of the admin area.
I have the login setup and a database that assigns the role names a number.
I'm not sure if there is a valid tutorial, they are probably older but still relevant if you check the tutorial library. MySQLi wouldn't change the concept, but the screenshots might be out of date.
Anyway it is a pretty simple concept. If you take it step by step it all makes sense.
1) User role is saved in the users table
2) Save the role in the session by adding it in the Authentication Server Behavior
3) Create rules in Security Assist based on the role session variable saved in step 2
4) Apply restrictions on the page based on the created rule
If you get stuck on a step, describe what you tried, maybe add screenshots, and post back and I can try to help you through it.
Richelle
I got it figured out.
