On page https://www.accessadviser.uk/contact.php I have some large empty spaces under the menu. Can anyone please inform me why this is happening?
Thread begun 10/16/2023 12:19 pm by john70964 | Last modified 3/04/2025 12:13 am by anonymous | 2234 views | 6 replies |
john70964
Google is declaring
Mobile Usability
Text too small to read and it maybe because of the large space under the menu
PatriceWebAssist
Look at line 40 in p7AMM-01.css
Default is padding: 6px 3px;
.p7AMM ul li {
list-style-type: none;
vertical-align: middle;
display: inline-block;
position: relative;
padding: 0px 0px;
~~~ updated note~~~
You weren't referring to the white space within the menu. Apologies. You mean the next section down, near Contact Details?
This is a Project 7 set up. P7 forum is down; Gerry said they were working on it. In the meantime he will answer in email: support@projectseven.com
john70964
Thanks Patrice,
The problem is solved now so thanks for your comments.
John
Jamie
If its the area thats above and below the 'Contact Details' text (as shown in pink in the attached screenshot), then its to do with a ratehr large lineheight set.
On line 333 of the css file p7HMY-01.css you have
.p7HMY .hmy-content p:first-child {
margin-top: 0px;
font-family: Verdana, Geneva, sans-serif;
line-height: 20;
If you remove the line-height line then you will lose all that white space.
Hope that helps and is about what you're treying to do
john70964
Thanks Jamie that seems to have solved the problem completely.
Many thanks
John
Jamie
Glad it worked John
anonymous
HOW TO RECOVER LOST BTC
This post has been deleted.
