"transaction not completed" error
Thread begun 10/24/2023 1:59 am by yogastudents362523 | Last modified 11/05/2023 5:26 am by yogastudents362523 | 1342 views | 3 replies |
yogastudents362523
Hello,
On checkout.php.
If I try using PayPal option, simply get the message:
"Things don’t appear to be working at the moment.
Please try again".
If I use CC option,
When filled in address details OK
page jump-scrolls to CC data section
Fill that in, hit Submit ...
always used to go to confirm.php with no issues
but now ... REPETITION
am instead being confronted for second, sometimes third time with request to resubmit CC data
on confirm.php
this did not used to happen
but fill in data and submit
then goes stragith to checkout_failure.php page and get message saying "Transaction Not Completed"
will put page url in upcoming private area
Thank you
yogastudents362523
If anyone is monitoring this, and it matters to them, I have at last fixed this issue.
Sincerely hoping you are all doing OK.
Thank you for everything over these many years.
KAB
PatriceWebAssist
Please post the solution.
yogastudents362523
Sure thing.
I apologise. We all need to learn to be better community members, now. And every little helps.
This was fixed simply by restarting the server.
Nothing wrong with Ray's code. Or with eCart.
Restart was all it took.
Took me over a week to get to that.
First went to "authorize.net"; then "TSYS". No help.
Then thought to investigate on Google for any similar errors in PayPal
After wading through so much fluff and irrelevancies, eventuall zeroed in on the following error as the most likely:
"Cause #3 – Your server is blocked for external CURL calls.
Solution: This needs to be checked with your hosting service since this configuration cannot be modified without administrator access to the machine. We suggest you get in touch with your hosting provider and ask if there are any restrictions on cURL calls or even firewall rules to block any outgoing requests."
Went to my server company and they were no help because my PHP 7 specs were fine.
Evetually, I just thought, why don't I just restart the wretched server, just in case.
So went into Plesk and hit appropriate button. Waited 5 minutes with bated breath. And kaboom.
Everything fine.
So ... if stuck, try restarting the server. Especially with as fine a standard of coding as Ray has put in his software.
Thanks. And let's all remember that sometimes switching gadgets off and then on again really does work!!!
Please be well.
KAB
