MySQLi Login User with Session Variable Problem
Thread begun 12/27/2023 4:35 am by DeanCollins | Last modified 12/29/2023 1:15 pm by Mags | 1549 views | 4 replies |
DeanCollins
I have a table with only two records at present. This recycle_site table has the site supervisors email and password. At present, for testing the emails of the two supervisors are distinct. However, when I log in, and go to the index page, only the first record is displayed on the page. Using the site supervisor's email in the second record still produces the first site supervisor on the page.
I've attached the login and index files.
Any help would be appreciated.
PatriceWebAssist
Dean:
During this period of transition, please post files in the public area so peeps can review.
Ray has passed away. We are relying on other users to find solutions.
DeanCollins
Here are the two files.
PatriceWebAssist
thanks..
https://www.mcwd.org/index.html
Mags
You haven't added a Repeat Region around the information you want listed, so it's only displaying the first record. Select the bit you want to repeat, i.e.:
<p><?php echo($Recordset1->getColumnVal("site_id")); ?></p>
<p><?php echo($Recordset1->getColumnVal("site_name")); ?></p>
<p><?php echo($Recordset1->getColumnVal("site_apn")); ?></p>
<p><?php echo($Recordset1->getColumnVal("site_addr")); ?></p>
<p><?php echo($Recordset1->getColumnVal("site_super")); ?></p>
<p><?php echo($Recordset1->getColumnVal("site_superphone")); ?></p>
<p><?php echo($Recordset1->getColumnVal("site_superemail")); ?></p>
then in Server Behaviors, click the plus sign then WebAssist > MySQLi > MySQLi Repeat Region. Select Recordset1 from the dropdown list and click All records. This will then add the repeat region around the info above like this:
$wa_startindex = 0;
while(!$Recordset1->atEnd()) {
$wa_startindex = $Recordset1->Index;
$Recordset1->moveNext();
$Recordset1->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
It should also automatically change the number at the end of the first line of your Recordset from 1 to 0:
$Recordset1 = new WA_MySQLi_RS("Recordset1",$connForms,0);
