Email name of uploaded file.
Thread began 1/26/2024 8:57 am by BillHobbs | Last modified 1/29/2024 10:27 am by BillHobbs | 119 views | 2 replies |
BillHobbs
I have a form where someone can leave a response to a series of questions and also upload a file. On the page I use to create the email that gets sent the text field entries are working, but the uploaded file name isn't being sent. The file is being uploaded and the name is being stored in the database correctly. Should file names be handled differently?
Code samples:
<?php echo((isset($_POST["answer1"]))?$_POST["answer1"]:"") ?> <---works
<?php echo((isset($_POST["file"]))?$_POST["file"]:"") ?> <---doesn't work
Mags
I see you asked a similar question back in 2022, not sure if the answer Ray gave would still be applicable: https://www.webassist.com/forums/posts.php?id=46336
If that doesn't solve it, try using the Server Name binding for the file upload from the Bindings panel (see attached example screenshot).
<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["WA_UploadResult1_1"]["serverFileName"]; ?>
BillHobbs
You're right, but I did need to add the global <?php global $connSiteDB, $WA_DFP_UploadStatus; ?> at the beginning of the document.
