How to get latest version of Framework
Thread begun 3/20/2024 4:56 am by georgina_barrett_187762 | Last modified 4/19/2024 3:24 am by Mags | 1835 views | 6 replies |
Since upgrading to php 8.2. I am getting these errors...
Deprecated: Creation of dynamic property WA_Include::$Start_Dir is deprecated in /home/../public_html/webassist/framework/framework.php on line 5
Deprecated: Creation of dynamic property WA_Include::$File is deprecated in /home/../public_html/webassist/framework/framework.php on line 6
Deprecated: Creation of dynamic property WA_Include::$BaseName is deprecated in /home/../public_html/webassist/framework/framework.php on line 7
There are many more - but you get the idea.
I got similar depreciated errors for the mysqli folder - and after downloading the latest files (someone had kindly added them to the forum) those were fixed.
Please can you attach the latest version of the framework files so I can update these as well.
Mags
This is the latest version I have (v2.02), which works on PHP8.2. I think deprecated errors are just warnings though, and if you turn error reporting off it should be OK anyway.
Dennis
I see my framework.php (attached) is version 2.08.
Dennis
PatriceWebAssist
Thanks to all for updates to this extension. I have only used it once while working on a complex project with Ray.
There is an alternative though. Use php includes.
1) set up a php page that has all you need to be "included"
2) strip it down to just the php, ie, no html, body, etc code
3) open the page you want to "include it" in, and do an insert php include.
I use it this way for headers and footers.
While framework is slick, it isn't the only way to do it. And with all we are challenged with now, it may be easier to try the php include approach. Just my humble opinion.
As an example on a page I'd add this:
<?php include("2024includes/header.php"); ?>
and the header.php has only divs, no html, body code etc.
<div class="col-1-3 centered padding1"><img src="../2024images/blue2014sketch.png" width="297" height="105" alt="logo"/>
</div>
repeat for footer with same approach
I used it here:
https://biz-comm.com
Thank you. Much appreciated.
I don't know if I need to create a new post for this, but I am have a similar problem with DataAssist Create Email.
I am getting lots of these errors:
Deprecated: Creation of dynamic property WA_Email::$SMTPAuth is deprecated in /home/travelsaversolut/public_html/webassist/email/WA_Email.php on line 135
Deprecated: Creation of dynamic property WA_Email::$SMTPSecure is deprecated in /home/../public_html/webassist/email/WA_Email.php on line 136
Deprecated: Creation of dynamic property WA_Email::$StartBurst is deprecated in /home/../public_html/webassist/email/WA_Email.php on line 137
Deprecated: Creation of dynamic property WA_Email::$StartTime is deprecated in /home/../public_html/webassist/email/WA_Email.php on line 138
Is there a latest version of WA_Email.php I could download?
Mags
You can generally ignore Deprecated errors, they don't stop the page from working, although may need to be looked at in future PHP versions. Just remove error reporting from the page and this will disappear.
I've attached the latest version of the WA_Email.php file along with the phpmailer folder - if you replace the file, you'll also need to replace the contents of the folder.
