I can't get connected to the database using DW CS6 and the WA Database connector
Thread begun 3/27/2024 2:36 pm by BjB | Last modified 4/07/2024 1:56 pm by Patrice | 1341 views | 5 replies |
BjB
I can connect if i write the script, but then I don't have the ability to use the Server Behaviors tab.
Mags
Can you provide more information and let us see the code? (Remove the database login details before posting)
Is it a local or remote database you're trying to connect to? Are you using a mySQLi connection? CS6 is very old now so not sure if that may be an issue.
PatriceWebAssist
I still have CW6 on older Mac Pro. If you can zip up the files, I can try to check it out.
BjB
Thanks for your help. Sorry it took me so long to get back to you.
I switched to a different hosting company and now able to get a connection to the database, but I get a lot of errors when DataAssist pages. I created a insert page with just 2 fields and even though it worked, I got a lot of errors and I'm unable to modify the page.
I am on Dreamweaver CS6. I also have Dreamweaver 2021 but I haven't tested it yet. PHPMyAdmin ver 5.4
I did use MySQLi for the connection
Jay Core Global Media
if you can provide the page minus any person info I could could take a look at it if its only 2 fields it would probably be not to hard to see what's going on
PatriceWebAssist
It is showing floaters missing. There may be corruption in DW.
See this thread: https://webassist.com/forums/posts.php?id=47226
I looked at your insert page and all seems in order.
Your error1 page shows that error.
