Activation
I activated the product today but when I try and work offline I am asked to activate it again. Is this correct?
If you close Dreamweaver, then open it again, it will try to validate the activation. If you plan to work offline, open Dreamweaver, then open the extesnion once to verify the serial. Do not close Dreamweaver, then go offline.
