Java Scrpt Error
Thread begun 9/26/2009 11:43 am by smooopi126872 | Last modified 9/26/2009 12:18 pm by office172461 | 3486 views | 3 replies |
smooopi126872
Java Scrpt Error
I recently removed my old version of CSS Menu Writer (via the extension manager) and upgraded to CSS Menu Writer 2.0.3. After I selected my options for my menus, I hit ok to generate the code and received a JS Error message:
"While exectuing onResize in WA_SiteTools_Progress.html, the following JavaScript error(s) occurred:
In file "WA-SiteTools_Progress":
refreshUI is not defined.
After hitting ok, i get this message:
Error generating menu (wa.generate.menu): TypeError: MM.WA_createProcessingOjbect is not a function.
As a potential resolution, I uninstalled the Menu Writer, rebooted, and then reinstalled it again. Unfortunately, still same error message. Anything thoughts on how to get the menus to work?
office172461
Try deleting the cache:
146/
smooopi126872
That did it. Thank you.
office172461
You're welcome.
Thanks for reporting the results.
