Email
Thread began 3/03/2009 8:22 pm by jgsb2001352074 | Last modified 3/29/2009 11:25 pm by dan_m343359 | 4318 views | 7 replies |
jgsb2001352074Beta Tester
Email
Hello:
I am having a problem with the email and thank you page rendering.
My database is catching the user inputs (ie is recording the data), but:
1. the 'Thank You.php page does not load after (another form loads)
2. the email is never sent
Here is where you can access the registration form:
users_Registration.php
Any help is greatly appreciated.
Jon
Probably the referrer checking and your security settings.
You can probably update the line:
if ((($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST))) {
with the line:
if (isset($_POST["Register_x"]))
That should stop the referrer validation.
Line Removal
Ray, thank you very much for your reply. I will test when I get home tonight and post what the results were.
Just to clarify what I will do:
DELETE:
with NO additional curly brace deletion, }?
ADD:
with NO curly braces at all?
Thank you again!
Jon
sorry, no add the curly bracket at the end
or just replace the contents of the IF statement even better.
Working, New Question
Ray, thank you so much! That worked great.
Now my Login and Forgot password pages won't work. They are doing the same thing as the user Registration was . . . posting to itself, only this time nothing happens.
1. I have confirmed the registration via e-mail
2. I looked for a similar line to the User_Registration page you told me about. I found in the user_Login.php that was very similar to the line you found for me earlier.
My question is: What Post value should I place there? "EmailPW_x", "Forgot_x"?
Any help is really appreciated.
Thanks again Ray.
Jon
That is the name of the submit button, or the name of the submit image with "_x" added to the end. So look at the name of the button the user presses to initiate the action and update the code accordingly.
Outstanding
Ray,
Many thanks for your direction, suggestions and support. Everything is working great.
Have a great weekend.
Jon
dan_m343359
User Registration Pack
Problem:
I cannot get the email registration confirmation page to send out from my remote server - Hosted by Go Daddy. I have been working with WA's Eric, for 3 weeks trying to resolve this. His last comment was for me to change hosting - Doesn't anyone have one of your URP working at Go Daddy ?
The database receives the registration / log in, no problem - PHP MyAdmin locally / remote
I really need a fix on this. My client is getting very impatient........
Dan
Update - Monday afternoon
Received a call from WA Ray - Got it going - now working on Go Daddy - apparently there were some code issues.
