Google Maps not showing start address anymore
Thread begun 10/06/2009 10:00 am by siteontime | Last modified 10/07/2009 11:07 am by Jason Byrnes | 3650 views | 4 replies |
siteontimeBeta Tester
All of my sites that use google maps no longer show a starting point. The starting point is undefined now. Even your power store demo is not working. Same issue.
AboutUs.php
Is this a problem with google?Or is there some update that I need. I am using version 1.05.
There must a be a recent change that Google made causing the problem, can you send a link to one of you maps that displays the problem so I can take a look?
I posted the link to the powerstore demo which is not working, and here is another one
location.php
I have 15 sites and all of them have the same issue.
Thanks for your help
Anyone have an idea on this issue? I have tried changing a few things.
If you change this:
directions.load('from: ' + fromAddress.full + ' to: ' + address_0.full);
wagmp_map_1_obj.directions = directions;
to directions.load('from: ' + fromAddress + ' to: ' + address_0.full);
The address displays, but the directions no longer work.
Any suggestions would be greatly appreciated.
find the line:
if(!fromAddress.enabled || 'address_0' != 'address_0') {
and change it to:
if(!fromAddress.enabled || 'address_0' != 'address_0' || fromAddress.full == 'undefined') {
also change:
To:
if (fromAddress.full != 'undefined') {
