HTML Editor (iRite v2) = New PowerCMS Version ?
Thread began 10/06/2009 3:50 pm by Dave Buchholz | Last modified 10/07/2009 6:29 am by Dave Buchholz | 1287 views | 4 replies |
Dave BuchholzBeta Tester
Will the new HTML Editor (iRite v2) be integrated into the existing PowerCMS or will we see a upgrade ?
Curious as I have a new project that I need to start that I was thinking of using PowerCMS to control some of the pages.
We will probably be updating PowerStore and PowerCMS to include the new editor, but if you have the new extension it would also be very easy to open and update to the new version in the existing version. The updates will not come out simultaniously.
Thanks Ray, so as normal I can just "inspect" it and the site files will automatically updated or will I need to make a change and save ?
I'd have to check... You may actually have to delete the editor folder in iRite, then inspect and click OK. I believe it won't overwrite the files once they exist in case you have hand edited or updated them. You shouldn't have to actually make a change in the interface.
I'll try later with the latest dot release of iRite and see what happens.
