I need some help with validation
Thread began 3/04/2009 7:10 am by sommar340908 | Last modified 3/04/2009 11:15 am by sommar340908 | 5440 views | 6 replies |
sommar340908
hi,
i made a form but on the very beginnig i have a list/menu with 2 entries. the validation works fine for all other fields, exept for the list/menu.
here is the script, i hope anybody can help me with this
thank you
<label for="Anrede" >
Anrede: <br />
<select name="Anrede" id="Anrede">
<option selected="selected">Bitte Ausw&auml;hlen</option>
<option value="Herr" <?php if (!(strcmp("Herr", (ValidatedField("contact","Anrede"))))) {echo "selected=\"selected\"";} ?>>Herr</option>
<option value="Frau" <?php if (!(strcmp("Frau", (ValidatedField("contact","Anrede"))))) {echo "selected=\"selected\"";} ?>>Frau</option>
</select>
<input name="addblock" type="text" id="addblock" style="display:none" value="" />
<br />
if (ValidatedField("contact","contact")) {
if ((strpos((",".ValidatedField("contact","contact").","), "," . "1" . ",") !== false || "1" == "")) {
if (!(false)) {
<p class="promo">* Bitte geben Sie ihre Anrede ein</p>
<?php //WAFV_Conditional contact.php contact(1:)
add : value="" to your top option.
sommar340908
hi ray,
i did this before but it won't work
It should... what is your validation code on top of the page?
sommar340908
ray, i did it again now with the value. but the selected value "Auswahl" means only "select" (in the code below it is in german). so if i don't touch the list/menu the validation don't tell me that i should choose between "Herr" or "Frau".
the validation code on top = $WAFV_Errors .= WAValidateRQ(((isset($_POST["Anrede"]))?$_POST["Anrede"]:"") . "",true,1);
<option value selected="selected">Auswahl</option>
</select>
<br />
if (!(false)) {
make sure it has:
<option value="" selected="selected">Auswahl</option>
other than that it should work.
sommar340908
ray
this solved my problem ;)
thank you very much
