Restrict Access on eCart Display Page
Thread begun 10/15/2009 7:11 am by kevin347925 | Last modified 10/16/2009 1:23 pm by kevin347925 | 2133 views | 2 replies |
kevin347925
I am not sure if what I am trying to do is even possible, but I would like to set some show if conditions on my cart display page. I made a rule to exclude a certain description when eCart object conditions are met. However, when I upload and test my page, I get the following error.
Fatal error: Call to a member function DisplayInfo() on a non-object in /home7/commonsc/public_html/WA_SecurityAssist/HelperGroupsRulesPHP.php on line 8
The following includes line 8 in the code.
function WA_Auth_GetComparisonsForRule($ruleName){
$comparisons = array();
switch ($ruleName){
case "Candle":
$comparisons[0] = array(TRUE, "".$CommonScentsCart->DisplayInfo("Itemtype") ."", 1, "CD");
break;
case "Manual":
$comparisons[0] = array(TRUE, "".$CommonScentsCart->DisplayInfo("Price") ."", 5, "140");
break;
return $comparisons;
function WA_Auth_GetGroup($groupName){
$group = Array();
switch($groupName){
return $group;
Thanks in advance.
Kevin
You wont be able to use Security assist to create these show if rules.
It would be easier to hand code them. For example:
<?php if($CommonScentsCart->DisplayInfo("Itemtype") == "CD") { ?>Show something<?php ?>
or:
<?php if($CommonScentsCart->DisplayInfo("Itemtype") > "140") { ?>Show something<?php ?>
kevin347925
Thanks so much, Jason!
