Trouble creating div within div
Thread begun 10/21/2009 6:09 am by mrs | Last modified 12/16/2009 2:25 pm by Jimmy Wu | 11105 views | 15 replies |
mrs
I have got a problem with CSS Sculptor 3 where I am trying to create a div within a div... actually, it is within four divs!
I have divs named and in this order:
footer, footerWrapper, footerTop, footerButtons... and then this is where the problem is coming in!
I am trying to create one further div where I am hoping to call it footerButtonMiddle, but any name I try to give it reverts back to div. Any settings I give it are not taken on board, and the preview is not registering the changes either. Is there any reason for this, or is it a glitch in the software?
Thanks.
mrs
I have just looked at the css code created, and the divs that are five layers down did create, but only with the default name of div1 or div2 (despite what I attempted to call them) and they did retain and the attributes that I specified, but for some reason, even though it visually looked to be in the right position of footer, footerWrapper, footerTop, footerButtons, div1 the css code created with it at the top level under outerWrapper, div1
Is it wrong to have this many divs inside each other? Is that why it doesn't work?
Dani Chankhour
When you created the nested divs, were you able to see the names of the divs changes in the tree structure. You might need to click on the tree structure in order to save the changes.
mike271728
Im getting the same problem with CSS S 3.0
Clicking doesnt help neither does restartng it seems that you can add X amount of Divs then it stops aloowing renames.
Also no the names do not change in the tree structure.
mike271728
Any news WA on a fix or cause of this?
I am not able to reproduce the problem.
I created 25 divs, each one I was able to rename.
My steps where to select the contentWrapper div in the tree, then click the plus button and select div. In the Name box I would change the name of the div, for testing i was using div<n> where n is a number. Then select the div above it in the tree (for example the content div) to see the name change take effect in the tree structure.
How many divs are you adding?
What are the steps you are taking?
MikeH
Personally Im doing the same thing as you only added around 5 divs and renaming stops.
MikeH
Ive just retried just make sure Im not missing something I now can not add more divs and certainly no renaiming..
I am using the latest build.
Getting frustrated as I habe not had trouble with Sculptor previously so now its causing a hold up.
To add a little more strangeness to this issue, I have just tried with a new design and you are right I can add as many Divs as I want and they all rename no problem.
As soon as I go back to my design it fails again. I have not edited any files outside of the interface so it seems very odd why this CSS Design has stopped alowwing functions. Any ideas appreciated.
MikeH
Right recreated all my work from scratch and all was well but then Sculptor decides that it will start doing odd behaviour again with not showing correct settings for Divs and selecting the wrong ones.
jonathan395400
Problem Creating Divs
Hi All,
I am posting here as my own issue appears to be simillar. Scupltor 3 and when I first modify a design layout by adding further divs all is OK. I save it as a present, but when I then try to add divs by modifying the new preset that I have created I get all types of issues:
Creates the default div, but loads values from another div further up the tree including name. Changing name only changes the div from further up the tree that was initially pulled in and leaves a default div which I can not edit its properties destroying the design in the process.
Very frustrating to the extent that I have now ditched Sculptor 3 and gone back to hand coding.
I have made a ScreenCasst of the issue for you all to look at.
WebAssist.html
Does anyone have a fix or solution to the above.
