QueryString Binding javascript error
Thread begun 10/28/2009 9:42 am by wbrooks199805 | Last modified 1/11/2010 11:40 am by Eric Mittman | 6742 views | 13 replies |
wbrooks199805
I am trying to add the sorting feature on the results page and getting error when get to the part of the online tutorial to add the querystring binding, add sort, when I do it says "javascript error..you have no query on the page". Then it shows query, no sort and the popup window goes white and crashes dreamweaver. I have deleted the sorting in the recordset.
Have you tried deleting the cache file or renaming the config to see if it helps to resolve this issue? If not please give this a try, here is a link to a page that lists the steps for clearing the cache file as well as renaming the config:
146/
If you have tried these things and they do not work let me know so I can check this out more. Also, if you continue to have problems please also post some screen shots of what you are experiencing.
wbrooks199805
thanks
I will try this out
wbrooks199805
not working
I did close down dreamweaver, created another configuration file, deleted all extensions, put all new extensions in and now getting errors with securityassist..I am uploading screen shots..
info321189
Hello, I also get error...
" While executing timer in WA_QueryString_Binding.htm, a JavaScript error occurred. "
I try to delete .dat file and install version 2.0.6 but nothing...
To wbrooks, are the errors you were getting for DataAssist gone now? Also, what is the OS version you are working with and are you running on a PowerPC or intel based Mac?
To info, did you try the troubleshooting techniques listed here in the previous posts including deleting the cache file and renaming the config?
wbrooks199805
Yes and yes
I mean I tried both and I am NOT getting results. I did all of the above. I did tell you that already on my other post.
Still getting the same results. other people are also........
Are the errors you were getting for DataAssist gone now? If these errors are not gone what is happening with them now?
wbrooks199805
still getting errors in both
Update to new computer Apple 10.6.1 CS 3 and still getting this error. Also doesn't work on apple 10.4.
So its a complete new install of everything!
Are the errors you are getting only in Security Assist now or are you getting errors in both tools? Please be very specific and post back with exactly what errors you are currently getting in what products and the steps you are taking that result in these errors for both.
