Some links work, others don't!
Thread begun 11/03/2009 6:54 am by jth370895 | Last modified 11/12/2009 12:04 pm by Eric Mittman | 6407 views | 10 replies |
jth370895
Good day,
I hope you can help me. I am an HTML newbie, excuse me.
I made an HTML side based on the menustructure from MW, all from templates. Some links work correct, others don't. From the index page I can reach all, from some pages I can link further ( like "varkens" and "schapen en geiten"), but from most of the links navigating ends. I think I have a small code problem, but I can't find it. I am working on this problem for several days, so I hope you can tell me how to solve this issue.
The site is located:
Index.html
I hope you can help me. Thanks anyway. Greetings Jan-Theo
Office Guy-172461
The # needs to be removed from the end of the links:
Index.html#
jth370895
Thanks for your quick reaction. Where can I find that "#" ? It is not in the MW edit menu and not in the files. So maybe you can give me an example how and where to find it in the code?
jth370895
Hello Mr. Office-guy 172461
Will you please help me? I am starting to become a little desperate. So another time:
- How can I remove that "#" ?
- Where to find? I can not find it in the MW edit menu or in the file menu.
I am using DW CS4: There are no broken links, but whith the validation I get several errors in CSSMenuWriter\cssmw(0)\treexml.xml with te description: " The prefix 'mm' has not been mapped to any URI[xml] ".
Has this something to do with my linking problem?
I would be very pleased if you find some time for helping me.
Kind regards from a bit desperate Jan-Theo.
When I view some of the links in your site it seems that they are not actually going to any pages and instead have just a # present for them.
To change this you would need to edit the contents of the menu on the page and specify pages for each of these links that are not going anywhere. You edit the contents in the property inspector by selecting the menu on the page first.
jth370895
Thanks Eric
Your advice helped me a lot, as you can see on the website. But I have still some questions:
- How can I link the content of the first or second level menu? I can not make these visible
in DW pageproperties, so linking seemed impossible!
- Why can I reach "\Bereikbaarheid\Vestiging Leende" when I come from "\Welkom" and not
when I come from another menu item?
- Suppose that my website would contain 100 or more pages and I want to create another
menu item. Should I link and edit in that case all 100 pages? This was for me the most important
reason to buy Webassist MW, because I thought that in that case MW did the job for me.
I will be very pleased to hear your reaction. Greetings from Jan-Theo.
I think that you might benefit from using a template file. If you have a template file you can keep all of the common elements here on the template then just update the pages for the unique content that they will have.
If you apply the menu to a template page it will automatically propagate to the derived pages and adjust the links for your on these pages. This way you do not have to account for the different page locations.
To create a template in DW you can just template on the new page dialog that appears. If you want to update a page to use this new template you will need to open that page and under Modify > Templates you can attach the template to the page.
If you do not do it this way then you will need to have an instance of the menu on each page, if the pages are linked to differently then this can cause problems for you.
jth370895
Updating?
Thanks Eric for your helpfull comment.
I made a new site, consequently from a template. This site works fine as you can see below. I still have questions:
- When I made a change in the template lay-out: when saving and updating DW tells me 15 pages have been examined and 15 pages are updated!
- When I made a change in the WA menu structure from the template: DW tells me 15 pages have been examined and 0 have been updated!!
Then in all the pages I edited the WA menu, horizontal and vertical. The only thing what I had to do was applying and finishing. Then in liveview it looks good! But 15 and more pages in this way updating is not what I expect from WA MW!! When I finished the job there were about 50 broken links. After correcting these links, everything looks and works perfect, as you can see below.
But I think, and hope, there should be an easier way to update the CSS MW layout? What did I do wrong?
With greetings from the Netherlands, Jan-Theo.
index.html
If you have the menu properly applied to a template page then there should be no need to update any of the individual instances on any other page, in fact you should not be able to make edits to these other menus if it was applied in the template properly. In the template you must have the menu in a common area, not an editable region. If it is inside of an editable region the code will not properly propagate to the other pages that are derived from this template. If done correctly you should not need to adjust the links to any of the other pages. Please let me know if you continue to have any problems with this so we can look into this further.
jth370895
Problem defined and solved!
Thanks Eric, this was the support I hoped for. I had indeed put the menu's in an editable region. Now I think everything works fine, no problems.
Maybe I am wrong, but I have looked for this information in the PDF explaning files, but I could not find it! Perhaps a good reason for updating?
Thanks anyway.
