Not sure which is the best option for me
Thread begun 11/03/2009 5:37 pm by sfurley1983390133 | Last modified 11/06/2009 10:41 am by Jason Byrnes | 3088 views | 3 replies |
sfurley1983390133
Hi I have created a website for chap who will be renting cars in Morocco, he began by asking if i could just setup an email form which was fine, but now he and his partner have had a rethink and would like to be able to rent the cars online, i.e works the same as the www.hertz.com website, someone uses the drops down menus decides when they would like the car from and to etc, then eventually prebook by paying online.
Now i was thinking of purchasing the powerstore 2 software and using that to do this but as I have never done such a site I'm not quite sure if this is the right approach? (he's happy to pay for it)
Sorry if I'm not using the forum the right way wasn't quite sure what this would come under?
Anyway could you please provide me with some advice as technically the person ordering wouldn't be receiving an item more like a confirmation email suggesting the time and place and agreement etc?...
Hope this makes sense thanks Steve
p.s. oh one last thing does taht person need a special account to set this up i have hear they will need a buisness account at their local bank is that true?
Thankyou in advance :-)
You would have more trouble modifying PowerStore to accomplish this than using the supper suite to create this from scratch.
to be honest up front, this will be a rather large undertaking, and will require hand coding PHP and creating the MySQL database structure. as well as creating complex SQL statements. If you are comfortable creating SQL Sub queries and JOIN Queries as well as coding PHP and creating Databases it should not be terribly difficult.
You would need to create a table of the available rental cars.
and another table to hold information about the cars that have already been rented: Which car, what date date it was rented on, when it is returned etc.
When the customer selects the start and end date, you will need to check the rented table to eliminate cars that are not available.
The results page will show only the cars that have not been rented for the date range selected and the customer can place that car in the basket, then checkout.
on checkout, the information of that rental will be stored in the rental table.
sfurley1983390133
Hi again
Thank you for your reply
index2.html
Here's a link to the website just a mock up at first they just wanted emails sent now they would like this money bit added...
They only other bit would be where they would like to pick the car up from, which is just 2 places & only have 5 of each car.
So let me try and get this straight is it possible for someone to buy using the ecart software and a debit/credit card because i thought that was only possible using the powerstore 2 software.
Also out of the super suite which bits would i actually use?
Is it just the database and the ecart bit?
I might know someone who can do the difficult hand coding bit, i mean would their be a lot of it?
I generally pick things up quick, is this REALLY COMPLICATED? I can hand code html, and i just setup a power cms website, is that a walk in the park compared to this? and should i just hand this over to someone who's done it before.
Honestly no offense taken if you think that's a better idea?
Sorry to be a pain just not sure which way to go, i feel it would be a great thing to learn to do but if its extreme hand coding mmm?... not sure
Whereas if it's a case of using wizards etc setting up an sql database with dreamweaverI can do it,
Thanks in advance
Steve:-)
Yes, eCart can be used to create an online store that the user can purchase using a credit card.
That functionality of power store was created using eCart.
Where you say you pick things up quickly, you *may* or may not be able to pick how to create this. Keep in mind that are a number of things you are going to have to pick up quickly though. There will be a fair bit of PHP coding involved in this, you will have to get familiar with creating a MySQL Database, and relational datbase design. You will also need to get familiar with creating complex MySQL Queries using SubQueries and Joins.
Yes, setting up PoweerCMS is a walk in the park compared to what you are trying to accomplish. With PowerCMS all the logic has been created for you, for what you are trying to do, you will need to figure out the logic and how to implement it.
If you decide to do this yourself, the best advice I can give is:
1) Don't impose a dead line. or if you do, be very realistic, you will probably need to double whatever you *think* you can accomplish it in.
2) Draw a flow chart of how you think the site should work. Then work on each piece one at a time. if you think in terms of "a leads to b" then figure out how to make "a lead to b" before moving on to the next step, it will become a lot easier.
