Contact Form Solution Pack 1.0.2
Thread began 4/22/2009 9:52 am by ddix341889 | Last modified 4/22/2009 12:35 pm by Ray Borduin | 2509 views | 3 replies |
ddix341889
The new updated Contact Form Solution Pack 1.0.2 doesn't give any update information on how or what to install. It just states "Updated to use Universal Email’s latest code base" so do we upload that folder only to our site?
You probably should not update existing applications unless you are experiencing a problem.
Once you have done customization it is difficult to determine what you should or shouldn't update. My opinion is don't update anything unless you are having a problem with something and use the new files for new pages you develop or start over with the new ones if they have functionality you want to add.
ddix341889
Thanks I wasn't sure what to do. So I should use the updated versions on future pages?
Correct... or if you ever decide to redo the current pages, or if you run into any other problems then you can work with support to find which files you would need to update to address them.
