Where's the Wizard?
Thread begun 3/05/2009 9:53 am by kirk372646 | Last modified 3/26/2009 7:16 am by Ray Borduin | 5062 views | 3 replies |
kirk372646
Where's the Wizard?
I purchased SiteAssist Professional earlier this week and have downloaded the software. When I start Dreamweaver I get a java script error "wa_configuration.js (error 3)". DW then opens normally. When I go to "site" and select "build site with SiteAssist Professional" nothing happens. Is this related to my java script error? How do I get SAP running?
The errors are probably related. What is the full and exact error message you get at startup?
mhair93432
I just got the same message on start up. Here is the text
JavaScript error while loading AlternateSelClass.htm:
Unable to open script file "C:\Program Files (x86)\Adobe\Adobe
Dreamweaver
CS4\Configuration\Shared\WebAssist\Library\WA_Configuration.js" (error 3).
Thanks for any insight you can give Ray.
Update:
Now that I look closer, it appears when doing multiple commands as well, such as select parent tag, or collapse code section.
Now also getting this:
The AlternateSelClass script does not define the findServerBehaviors function when viewing the page where it is used.
It looks like one of the necessary files was not installed properly. I would post a support incident. I could tell you where to find a copy of that file and how to place it in the correct location, but my fear is that may not be the only file missing, so we should get somebody to look into it with you.
