Data Assist and CMS
Thread begun 11/06/2009 4:49 pm by mrs | Last modified 11/09/2009 11:47 am by Eric Mittman | 1677 views | 1 replies |
mrs
Data Assist and CMS
I have just added a table to the database of PowerCMS and then ran data assist to help me build admin pages to edit the new table. I have just tested the pages, and for the first time ever that I have run this extension, I have resultant pages that error. The error is:
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/linux/a/abc.com/user/htdocs/admin/seo.php on line 91
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/linux/a/abc.com/user/htdocs/admin/seo.php on line 95
Line 91 is: mysql_select_db($database_localhost, $localhost);
and 95 is: $WADAseo = mysql_query($query_limit_WADAseo, $localhost) or die(mysql_error());
The two lines are part of this:
$maxRows_WADAseo = 1000;
$pageNum_WADAseo = 0;
if (isset($_GET['pageNum_WADAseo'])) {
$pageNum_WADAseo = $_GET['pageNum_WADAseo'];
$startRow_WADAseo = $pageNum_WADAseo * $maxRows_WADAseo;
$query_WADAseo = "SELECT seoID, pagename, browsertitle, metatags, metadescription FROM seo";
setQueryBuilderSource($query_WADAseo,$WADbSearch1,false);
$query_limit_WADAseo = sprintf("%s LIMIT %d, %d", $query_WADAseo, $startRow_WADAseo, $maxRows_WADAseo);
$row_WADAseo = mysql_fetch_assoc($WADAseo);
if (isset($_GET['totalRows_WADAseo'])) {
$totalRows_WADAseo = $_GET['totalRows_WADAseo'];
} else {
$all_WADAseo = mysql_query($query_WADAseo);
$totalRows_WADAseo = mysql_num_rows($all_WADAseo);
$totalPages_WADAseo = ceil($totalRows_WADAseo/$maxRows_WADAseo)-1;
Have you got any advice on this as I am stumped. There is content in the MySQL table, it's a simple table, and yet I can't get the results page to display. The insert and search page (prior to a search) will display, but these don't seem to be calling anything from the database yet.
The error messages you are getting are referring to the db variables that should be in your connection file. The file should be listed in the connections folder as localhost.php. You must ensure that there is a require once line for this connection on the page. As another test you can do create a new page and apply a recordset to the page. If you can test the page with the recordset on it then you should be able to get this other page to work so long as the connection file is linked properly.
This line should be at the top of the page and it should look like this:
<?php require_once('../Connections/localhost.php'); ?>
Inside of this file you should have all of your information to connect to your db. Please check this out and run a test on a page to confirm the path to the connection file. If your pages links to this file in the same way it should work the same also. Let us know if you have any other problems.
