CSS Sculptor 2 waon't activate
Thread began 11/10/2009 1:22 am by anthony.tanner286315 | Last modified 11/10/2009 3:59 pm by Dani Chankhour | 1552 views | 3 replies |
I have successfully downloaded and installed CSS Sculptor on Dreamweaver 8 But when the activation screen is displayed there is an error message stating that no internet connection is available when clearly there is. Even the link on the interface works. When I submit the serial No it agrees that it is correct but then I get an error message telling me to Submit to Technical Support request with a link that also works.
I've never encountered this problem before
Please Advise
Dani Chankhour
Do you get this error on Sculptor only, or are you getting on all your extension.
If you could also tell me the platform and the version of Sculptor you are using to run a test on my end.
css scultor wont activate
Thank you for your reply.
I only get this on CSS sculptor 2 and as yet nothing else. CSS sculptor 1 worked fine but I uninstalled it thinking that it was conflicting. with sculptor 2. When I uninstall css culptor 2 it takes an age, but gets there.
regards
Tony Tanner
Dani Chankhour
I remember seeing an issue when installing sculptor 2 over sculptor v1. If the issue still exists please try deleting your configuration folder as some of the files might not have gotten updated.
This link:
146/
explains the steps on how to delete your configuration folder.
