Content Boxes
Thread began 3/05/2009 2:58 pm by mike271728 | Last modified 4/07/2009 12:21 pm by kevin_d_allen182238 | 6071 views | 12 replies |
mike271728
Content Boxes
Hi
By any chance is there a tutorial on adding content boxes using CSS Sculptor?
ie
In the main content area I want to add a couple of nice content boxes side by side then the rest of the content underneath (or above in some cases) any pointers into achieving this?
Mike
Contents are handled in SiteAssist and would not be added to sculptor. If there is a particular page type or look you are going for, post an example... it could be added to site assist.
mike271728
Hi
Thanks for the reply Ray.
As an example take your NEW home page you have 3 boxes on it
Help me Choose
Our Community
Whats New?
Basically that sort of idea. I wanted to use Sculptor to be able to control all aspects of colours layout rather than rely on Site Assist only.
Can this be done?
Mike
Justin Nemeth
In sculptor, you could select a 3 column layout as a starting point, then adjust each column accordingly to the size you want. After that, add a custom div above the contentWrapper. This would give you a larger area above the 3 columns (or boxes if you make then equal width) and should give the basic effect like on the WA home page. The box tab is really powerful in allowing you to add and position custom divs to achieve a more complex layout like you want.
mike271728
Hi Thanks for the reply.
Heres another good example of what I meant:
business-broadband/
This sort of site design is pretty common so an abilty to easily create these using wA Extensions such as CSS Scylptor and SA Pro would be fantastic.
Mike
The new version of Site Assist allows you to define your own page types.
You could manually create this content in a SA Pro site, and then save those contents as a page type to use in the future.
So you actually have the ability to add this feature if you own SA Pro, you just have to develop the page once (copy and paste that one if you like it).
mike271728
Hi Ray
I have SA Pro is there a tutorial on that way of working?
Mike
It should be covered in the help. It works like this, whenever you create a page with Site Asssist pro, it knows what your content area is on that page. So if you change the content, there is an option available to save that content. Once it is saved, it is available in the wizard. Should be pretty straightforward. Give it a try and let us know if you have any problems.
Just go to Insert->WebAssist->SiteAssist Pro->Create page type once you have created a page you would like to save and make available later.
Miguel
Ill try to explain it a bit here lets see open a new page on dreamweaver and click on the webassist tools for eric meyers CSS sculptor then select what ever layout you need on the first tab, then click the second tab "BOX".
There you will find a list look on that list for:
ContentWrapper
|---> Content
Now click over content and look for the button on the top that has a plus or Add simbol click over it and add under Content a new Div it would be something like this
ContentWrapper
|---> Content
.................|---> Div
Rename it to what ever you like i called it LeftBox.
Repeat again selecting the Content on the list and add a new one and so on until you are satisfied
check the picture attached to this post.
Ok after you got BoxLeft, Boxright, and BoxCenter add boxleft float: left this can be done at the properties options just below, you will find the option just after where you place the width and height also add a size example width: 200px height: 300 for BoxLeft.
Now select BoxRight, and do the same on width and height, 200x300, but select Float: Right.
And now select the last div you added wich we named BoxCenter dont add a size to it Dont!!!! just check down a bit more where you will see Margin & Padding, now here is the tricky part you have to play with the margin i placed all to 0px and the last one with is margin left i placed 200px example
Top: 0px Right: 0px Bottom: 0px Left:200px
ok done with that now click on padding and add what ever you need i placed 0px for all but u can play with it to make it look better, ok after this click on Design and add the backgrounds and settings to your need, also play with the size i placed all depends on how you want them look also depends on the size of the website i used the standard one by default to make the screenshot i placed here.
Good luck with it hope this helps :)
Pd forums needs a but of let us place codes like <strong> and shitz... and sorry my not so good english..
Miguel
damn sorry i forgot to mention and i placed the wrong screenshot its the same but i placed the names so u can understand box1 = BoxLeft, Box2 = BoxRight, Box3= BoxCenter,
also on the screen shot i colored the boxed on the design tab
Left = blue
right= red
Center= green
