Link open another window
some of my links in the nav bar are outside my website.
I want to set those button links to open in a new window.
How can I do that?
thanks
How can I do that?
thanks
You would have to edit the list content where the image links are and add target="_blank" to the existing <a> tags.
Is it better to get help here or with support ticket.
I put <a href="http://fsa-shuffleboard.org/" target="_blank">
in the link box of your edit module but it did not work
You will have to make the change in the code itself instead of in the edit module. It isn't supported directly through the interface.
got it thanks works ok
if at somepoint i want the normal behavior do i need to go into the code again or will your module just overwrite it?
It will overwrite it if you update the contents.
