Script crashes internet explorer during upload
Thread begun 12/06/2009 10:41 pm by J7HNW | Last modified 12/14/2009 11:35 am by Jason Byrnes | 6384 views | 7 replies |
J7HNW
Script times out
My Digital file pro works fine with small sized files.
On larger files - the script is timing out. The graphic showig the upload is working fine then it just goes to an internet explorer "pag can not be found " error so I assume the script has stopped.
How can I adjust the script please to run for longer ?
Page is attached
Tried the Web assist server timeout
// WA Set Server Timeout
if($_SERVER["REQUEST_METHOD"] == "POST"){
set_time_limit ("180");
Nothing happened
So I Have added this to the script
// script dies after 600 secs
set_time_limit(600);
Still no difference.
Any help appreciated
You also started another thread with the same issue. See the first thread you started for my replay:
showthread.php?t=8137
J7HNW
Please update
Jason
Please confirm code to extend upload time to 6 minutes and filesize to 6mb
Have tried to add the PHP examples you sent but to no avail
John
There is no exact code change to be made for those settings.
to increase the upload file size to 6MB, you need to increase the
upload_max_filesize
post_max_size
The post_max_size setting should be larger than the upload_max_filesize
to increase the script execution time, you need to adjust:
max_input_time
max_execution_time
if there image resizing occurring, you will also need to adjust:
memory_limit
if you are resizing images, you should increase the memory_limit to 256M
J7HNW
Lare file upload
Jason
Please advise where the changes should be made. Is it on the actual page or on a different page to control upload times and file sizes
I installed this for the server panel
Where should I add the items you suggested. Sorry I usually work with ASP and know nothing of PHP - excuse my ingorance
Should it look ike this ?
},{max_input_time ("180").
{max_execution_time ("180"),
{upload_max_filesize ("4096"),
{memory_limit ("256m"),
And should this be embedded at the top of the form ?
John
These settings can only be changed in the php.ini file:
max_input_time
upload_max_filesize
memory_limit
to change the max_execution_time in your script, add the following:
ini_set
('max_execution_time','180');
J7HNW
Please advse
The server people have set the times as per instruction - but still the uploader stops after around 20 seconds on large files. Small files are fine.
They have asked if you can tell me which settings need to be changed
Here are the PHP settings, do you know what needs to be changed, each time we make a change we need to restart the web server.
Please advise - PHP info file attached
Ir starts to upload fine - but then IE8 goes blank and displays " Internet Explorer cannot display the webpage "
Thanks Jason
It is impossible for me to know exactly what settings need to be adjusted. It depends on the size of the file you are trying to upload and how you have configured Digital File pro
maybe try increasing:
memory_limit 128M
memory_limit 256M
and :
upload_max_filesize 2M
to
upload_max_filesize 8M (or larger if you are uploading files larger than 8M)
and:
max_input_time 60
max_input_time 300
