error Helper_PHP.php
Thread begun 12/07/2009 6:47 am by Kamen Nikolov | Last modified 12/15/2009 10:47 am by Jimmy Wu | 3162 views | 5 replies |
Kamen Nikolov
Hello,
I am new in this. I purchased the User Registration Solution Pack, set it up and it is working OK so far, but I am getting an error in WA_SecurityAssist/Helper_PHP.php when I tried to log in as user on line 14 and 20 using users_LogIn.php:
Line 14: mysql_select_db($WA_Auth_Parameter["database"], $WA_Auth_Parameter["connection"]);
Line 20: $WA_Auth_RS = mysql_query($WA_Auth_loginSQL, $WA_Auth_Parameter["connection"]) or die(mysql_error());
I was wondering do I have to replace anything on these two lines like my database Name (my_data) and my connection name (../Connections/my_connection)?
Could this be an Apache web server problem or what else.
I will appreciate any help.
Thank you,
KN
Jimmy Wu
In the user registration solution pack, there is a connection file already in the Connections folder. You should modify that connection to have your server information in it. That would be the simplest way to get the connections to work correctly.
Kamen Nikolov
error
Hello,
Tank you for your response. The connection is working. This is the error/warning I am getting:
Warning: mysql_select_db() expects parameter 2 to be resource, null given in C:\xampp\htdocs\Luba\WA_SecurityAssist\Helper_PHP.php on line 14
Warning: mysql_query() expects parameter 2 to be resource, null given in C:\xampp\htdocs\Luba\WA_SecurityAssist\Helper_PHP.php on line 20
Jimmy Wu
What is the name of the connection you are using?
Also, does your line 59 of the users_Login.php page look like this:
"connection" => $localhost,
or is something else listed to the right of the arrow?
Kamen Nikolov
Thank you Jimmy,
I got this one working. I have another problem after a got everything working. When users register, they will receive an email and they will verify their email and will login into their profile. The problem is that if I update my profile locally is working when update on-line it is not.
You can try it yourself register at users_Registration.php or users_Registration_Simple.php and try to update your profile.
I have been over the code many times and can figure it out. Tank you for your help in advance.
This is the code:
Jimmy Wu
I copied your response to a new thread:
showthread.php?t=8455
Since its a different issue, it makes the forum more organized if there is a new thread for it. Someone will take a look at this issue and get back to you on it.
