uploading pages to server does not display page
Thread began 12/07/2009 2:21 pm by mr hankey | Last modified 12/08/2009 11:51 am by Jason Byrnes | 1419 views | 5 replies |
mr hankey
hi,
i seem to be having major problems with the extensions working online. anytime i run through the wizard, looks great on my screen but as soon as i upload it wont display the web page??
Can someone help me asap as i have tried everything changing php version and checking settings.
the template displayed fine with 2 editable regions set to site root within dreamweaver settings. as soon as i add dataassist wizard and upload i get page cannot be displayed.
any help would be great please.
many thanks
mr hankey
could anyone at all help me out with this?
many thanks
mr hankey
after some help from my hosting technical support i changed the virtual command to require_once which seemed to display the page, however when you fill in the insert page and click insert it refreshes to the same page but comes back saying page cannot be displayed? anyone got any advice with this?
Dreamweaver will use the virtual command if you set the option in your site definition to create links relative to the site.
If you change this to create links relative to the document, it will use the require once command instead.
To trouble shoot the problem, try adding the following code at line 1 of your page to turn error reporting on:
error_reporting
(E_ALL);
mr hankey
thanks Jason, the only issue is the if i change it to document and upload it looks for a file on C:\users\etc.............. which is just easier to edit the virtual command to require_once.
thanks anyway
Dreamweaver will generate file system links if you save the page outside of the site, and answer yes when prompted to update links.
