CSS Sculptor 3 - Preview won't load
Just purchased and installed Sculptor 3, and the preview does not display. It kind of defeats the purpose of the plugin. Is anyone aware of a fix?
MacBook Pro, OSX 10.6 - Dreamweaver CS4
Do you have any other extensions that have preview installed? Do the previews work in that?
Another user was able to resolve the issue by uninstalling their security software:
showthread.php?t=4487
Thanks for replying, but no... I don't have any other extensions installed, and I don't have any security software.
Just for clarification, are we referring the the Mac's preview engine?
I'm also having the same issues. Just purchased CSS Sculptor 3 and no preview. I have to click on the box to 'Open Preview'. Version 2 worked fine.
Mac OSX Leopard
DW3
Thanks,
Dan
If its any help. This was an issue in an earlier release of SiteAssist, but was fixed in subsequent releases of the software.
Since purchasing the Extension Library yesterday 12/15, I've lost the Preview for all the products (Sculptor, Menu Writer, Site Assist) for the Mac (Leopard, DW3).
These products were working before I upgraded. They were on older versions though...
Dan
Are you able to click on the preview window and view the page in the browser?
Also, can you check under edit->WebAssist Preferences under the Preview section that the Disable preview check box is not checked?
Yes, when I click on the preview box, it open (twice actually).
I did check the preferences and the disable was off. I did toggle it off and on to see if that would help with no luck.
That's the same behavior I get. Opens in the browser, twice. Still no preview.
What version of Safari do you have installed?
