error when inserting an Add To Cart button
Thread begun 12/13/2009 10:39 am by vmartinez310076 | Last modified 1/15/2010 3:01 pm by Jason Byrnes | 4089 views | 6 replies |
vmartinez310076
I am using eCart 4.5.2
When inserting the "add to cart button", I receive an error "Fatal error: Call to a member function GetContent() on a non-object in C:\wamp\www\Joint_Factors\joint_factors.php on line 6". The code on line 6 is $JointFactors->GetContent();
I also have 2 recordset fields on the page.
Is there a fix?
This error occurs when the Database connection and the eCart object have the same name.
You must use unique names when naming application objects such as the eCart object, Connections or recordsets.
vmartinez310076
Thanks for the help.
cyberdriveuk194445
insert add to cart
I have just upgraded the ecart fron 414 to 452 when I try to add a new add to cart button
it states I need to add object first there is already an object there from the previous version however it is not reconising this what should i do?
Is the page you are trying to add the Add to cart button saved to the same Dreamweaver Site as the previously created eCart object? The eCart object and the add to cart page must be members of the same Dreamweaver site.
cyberdriveuk194445
the site is the same site however its as if WA ecart does not think there is an ecart object there when there is an object there what should I do.
You have this same issue reported in another thread:
showthread.php?t=9189
