Will my database sessions work with WebAssist Extensions?
Thread begun 12/19/2009 2:44 am by Pro Covers FX | Last modified 12/21/2009 1:55 pm by Pro Covers FX | 3062 views | 2 replies |
Pro Covers FX
I have to convert a clients web site over using WebAssits Extensions.
Here is my problem!
The clients website after checking it is using a database session handler. not only that after viewing the code they are also logging guest users to a active guest table. Plus there are two other tables one for active users and banned users.
The site works like this, when a guest enters the web site it goes to the database session handler and adds the guest to an active guest table, now if the guest logs in they are removed from the active guest table and entered into the active users table.
All of this is handled through the database session class they have.
Ok, now my question is there any way that they can keep the database sessions and I can also use the WebAssits Extensions???
Thank you
Pro Covers FX
The WebAssist extensions should not interfere with any existing code or scripts on the site. The tools will create server behaviors that contain the code necessary for that functionality based on the options you choose.
If you need to work within the custom framework you will need to come up with a strategy of sorts for what functionality you want to add into the various areas of the site with the tools. You can then make use of the tools to apply this functionality in a modular fashion.
Please post back with any specific questions that you have about a part of this and we would be glad to help you out with whatever we can.
Pro Covers FX
[solved]
Hi Eric,
Thank you very much for your help, that answers my question. I just did not want any conflicts.
Have yourself and WebAssist a VERY MERRY CHRISTMAS...
Enjoy
Pro Covers FX
