help me in redirect
Thread begun 12/20/2009 6:36 am by alhero_94375722 | Last modified 12/22/2009 3:38 pm by alhero_94375722 | 6373 views | 9 replies |
alhero_94375722
help me in redirect
Hi i have to problem with login page and same in cart.php with continue shopping
When i login in i stayed on the same page and I want to go to the previous page
i try to add <?php echo((isset($_SERVER["HTTP_REFERER"]))?$_SERVER["HTTP_REFERER"]:"") ?> in action in the form but the problem
it go to previous page but i dont login in
and the same problem with the continu shopping in cart.php when i press the buttom i stayed in cart.php i reading all post in ecart section in forums about
this problem but without result
in attach 3 files 1 to my cart and 1 to login .php and 1 to php helper
and very thanx
For the login page, set the action of the login for to:
<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>
on the cart page, there may be php error occurring that is preventing the redirect, add the following on line 1 see if an error is occurring:
error_reporting
(E_ALL);
alhero_94375722
sorry
tanx jason but the problem not resolved in attach here full page login php
and for cart page alredy i but this script but dont show any error
thanx for help me
To trouble shoot, add a success and failure redirect to the Authenticate user server behavior. As it is right now, these are blank. this will at least tell you whether you have logged in successfully.
alhero_94375722
thanx
i am very jason but my problem not in login in but in redirect to preiveus pages befor login
add a success and failure redirect but i go to success page not to preveus page
and what about cart
very thanx
To go to the previous page, the address needs to be passed through the accesscheck querystring variable
What is the address in the address bar when you get to the login page? Does it contain the accesscheck querystring variable?
You can see an example of this by adding Page Access restriction to a page, set it to go to the login page if not logged in, then try to access it.
To debug the cart page, add the following code just after the body tag:
<pre><?php var_dump($_SESSION); ?></pre>
this will write the session contents to the cart page, post back the session contents.
alhero_94375722
very thanx jason for this help now the error in cart.php after i add <pre><?php var_dump($_SESSION); ?></pre>
is
array(3) {
["WAVT_detail_Errors"]=>
string(0) ""
["eCart1_Items"]=>
string(120) "1|WAECART|Avobath|WAECART||WAECART|0|WAECART|1|WAECART|29|WAECART|Avobath.jpg|WAECART|0|WAECART|29|WAECART|1 Avobath (1)"
["WAEC_ContinueRedirect"]=>
string(16) "/detail.php?ID=1"
OK, so the ["WAEC_ContinueRedirect"]=>string(16) "/detail.php?ID=1" variable is getting a value, make sure your cart page has the following code just before the <doctype..> tag.
// WA eCart Redirect
if ($eCart1->redirStr != "")     {
header("Location: ".$eCart1->redirStr);
alhero_94375722
very very thanx
thanx jason relly very very thanx two problem is resolved
and continu shopping is working 100% now i but i have small problem how i hide this error
array(3) {
string(0) ""
["eCart1_Items"]=>
string
(371)&#65533;1|WAECART|Avobath|WAECART||WAECART|0|WAECART|1|WAECART|29|WAECART|Avobath.jpg|WAECART|0|WAECART|29|WAECART|1 Avobath (1)"
alhero_94375722
thanx jason i remove<pre><?php var_dump($_SESSION); ?></pre>
and work 100%
and you know whats problem may be the <?php
?> alredy add when i setup up ecaart but it add before // WA eCart Update
but when i moving to before the <doctype..> tag it work 100%
thanx alot jason you are good man
