Server Upload Images Incorrect
Thread begun 12/20/2009 5:38 pm by debbie295402 | Last modified 12/23/2009 9:41 am by Jason Byrnes | 8939 views | 16 replies |
debbie295402
I've uploaded images from my server over 4 times, and each time the amount of images it says are uploaded and processed in a particular gallery do not match the amount of images I physically saw as they were uploaded. The images within each and every gallery do not match the processed images. I've double-checked the images on my server and when I view the folder from ftp as well as from within the Power Gallery, the amount on the server and the amount to be processed agree. It is the final image count that is incorrect. I've deleted and recreated each gallery with different image amounts and different folders. The amount of images that it shows each time is not consistent, either. One time I'll get 89 and the next 56.
Am I doing something wrong (although that would be difficult since the process is self-contained) or what?
As a test of this please try the following. Upload a small number of pictures that would be easy to recognize, I think ten images would do. Then add the images to the gallery to see exactly what the result is. I'm curious if the problem might have to do with the number or type of images you are using or if it is consistent even with a smaller sampling of images. Please post back and let us know what you experience when working on this smaller scale.
debbie295402
Between the time I posted & then got your response I uninstalled and removed all database files from the server, then uploaded & created a new install & db tables. I then tried to add images during the install. It froze at 135 of 155, but only recognizes 81. link is: index.php?gallery=1&theme=dark.
I then did as you requested and uploaded a test folder with 9 images. It processed all 9 within 15 seconds and shows 9 in the gallery. One of the pictures is 1.33MB.
The original pictures are all from the same batch and none are over 713kb. Average dimensions of each pic is 3000x2000. Hope this helps...
Thanks.
gruant2000381341
I was nosing around and noticed something, on image #20091107_0835.jpg: 20091107_0835.jpg . Half of it is grayed out, didn't know if this was part of your problem or not. Just a fyi
debbie295402
Interesting, gruant2000381341, and you are correct. I just checked the original picture that was uploaded, as well as the image within PowerGallery, and they are ok there... Weirder & weirder.
It is possible the server is running into a memory limit issue or the images being uploaded are exceeding the max file size limitation.
try adding the following at line 1 of the connections/powergallery.php file to increase the server memory limit, post max size and upload file max file size settings:
ini_set
('memory_limit''256M');
ini_set('upload_max_filesize''10M');
ini_set('post_max_size''10M');
debbie295402
Will I need to recreate the gallery(ies) once I've made this change? If so, should I remove the broken galleries first? Thanks!
Yes, you will need to recreate the galleries since they where not created correctly the first time.
you can either delete the existing gallery, then recreate it, or create a new one for testing.
debbie295402
I'm now getting the following error when I navigate to the PowerGallery folder online:
Warning: Cannot modify header information - headers already sent by (output started at /home/content/a/v/v/avvparade/html/images/PowerGallery/Connections/powergallery.php:7) in /home/content/a/v/v/avvparade/html/images/PowerGallery/admin/index.php on line 63
I only added the code to the powergallery.php file and uploaded that. Then navigated to PowerGallery to begin.
The code within powergallery.php is the following (I've replaced the actual info with place markers):
ini_set('memory_limit', '256M');
ini_set('upload_max_filesize', '10M');
ini_set('post_max_size', '10M');
# FileName="Connection_php_mysql.htm"
# Type="MYSQL"
# HTTP="true"
$hostname_powergallery = "[dbhost]";
$database_powergallery = "[dbname]";
$username_powergallery = "[username]";
$password_powergallery = "[password]";
$powergallery = mysql_pconnect($hostname_powergallery, $username_powergallery, $password_powergallery) or trigger_error(mysql_error(),E_USER_ERROR);
this is because of the blank line between the php tags that you have added.
your code should not have any blank lines or spaces after the closing php tags:
ini_set
?><?php
# Type="MYSQL"
# HTTP="true"
$hostname_powergallery "[dbhost]";
$database_powergallery "[dbname]";
$username_powergallery "[username]";
$password_powergallery "[password]";
$powergallery mysql_pconnect($hostname_powergallery$username_powergallery$password_powergallery) or trigger_error(mysql_error(),E_USER_ERROR);
