Getting Started Guides directory
Thread begun 12/21/2009 4:52 pm by Office Guy-172461 | Last modified 1/06/2010 9:20 am by Neil Beadle | 6507 views | 11 replies |
Office Guy-172461
I still can't download anything from the:
getting-started-guide/ directory.
I tried the right-click save trick with IE and FF using Windows and Linux and I just get a File Not Found error a few minutes into the download. The other PDFs download without problems.
Does anyone have copies of:
css_sculptor_3_gsg.pdf
search_for_boss_gsg.pdf
css_menu_writer_2_gsg.pdf
on their server that I could download?
Neil Beadle
Hey OfficeGuy,
Is it only the Getting Started Guides that you cannot download? If you aren't having issues downloading PDFs from other locations on WebAssist, then this might help us pinpoint the cause of this. We made a few changes a while back to resolve any PDF issues, but it seems as though a few users are still having problems.
As a quick test, i have copied these three files to the How Tos directory. If you can view these, then we'll try to take a look at any differences between the two locations.
Let us know if this works.
-Neil
Office Guy-172461
All three of these open right up with the standard left-click and I was able to save all of them in less than a minute.
I would say it's the directory that's the problem. Maybe shortening the name of the folder would help.
Neil Beadle
Thanks for the feedback. Now we have something we can look into and hopefully resolve this.
We also hope to have these all moved to our HTML format very soon. So, that will alleviate some of these issues as well.
Office Guy-172461
While we're waiting for a fix, goes anyone have a copy of:
web_standards_advisor_gsg.pdf
that I can download?
John LangerBeta Tester
Originally Said By: Office Guy-172461
Here you go web_standards_advisor_gsg.pdf
Office Guy-172461
Thanks so much John. Worked perfectly.
You're very welcome
WebAssist, the file is now removed.
Office Guy-172461
Originally Said By: Neil Beadle
Any chance you could copy the getting started guides to an alternate folder while you're working on this?
Neil Beadle
We've moved the getting started guides to a folder named 'gsg' instead of 'getting-started-guides' making the paths much shorter.
Hopefully this solves the issues some people were having.
Let us know if they persist, or if you come across any broken links that need updating.
-Neil
