Data Assist Issue!
Thread begun 12/21/2009 9:31 pm by sudeep.pavithran374974 | Last modified 12/23/2009 11:31 pm by sudeep.pavithran374974 | 6126 views | 9 replies |
Data Assist Issue!
Hello there,
I started using DataAssist recently in one of our site, and I used the wizard to create the admin pages. Everything works fine except Update & Insert pages. It gives me an error.
I am not good at PHP coding. Could you please guide me to fix this? Please find the url below.
clients_det_Results.php
Thanks & Regards,
Sudeep K Pavithran
CraigRBeta Tester
parse error
you have a php parse error (syntax) on the lines mentioned, can you post the relevant pages so someone can look at them in detail ?
The errors on the page give line numbers, so the problem is on those lines... for instance on the update page I see:
Parse error: syntax error, unexpected ';' in E:\inetpub\vhosts\alshirawifm.com\httpdocs\mod\clients_det_Update.php on line 34
what is on lines 33-35 of that file?
PHP code!
Hi..
Thanks a lot for the reply! Here I am pasting few lines from the code..
clients_det_Insert.php -- Error shows in the 9th line.
<?php require_once("Connections/authen.php"); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
// WA Application Builder Insert
if (isset($_POST["Insert_x"])) // Trigger
$WA_connection = $authen;
$WA_table = "clients_det";
$WA_sessionName = "WADA_Insert_clients_det"; --> this is the 9th line
$WA_redirectURL = "clients_det_Detail.php";
$WA_keepQueryString = false;
$WA_indexField = "clientname";
$WA_fieldNamesStr = "";
$WA_fieldValuesStr = ;
$WA_columnTypesStr = "";
$WA_connectionDB = $database_authen;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
clients_det_Update.php --> Error in the line 34
<?php require_once('Connections/authen.php'); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
$Paramclientname_WADAclients_det = "-1"; ---> This is the 34th line
if (isset($_GET['clientname'])) {
$Paramclientname_WADAclients_det = (get_magic_quotes_gpc()) ? $_GET['clientname'] : addslashes($_GET['clientname']);
mysql_select_db($database_authen, $authen);
$query_WADAclients_det = sprintf("SELECT clientname FROM clients_det WHERE clientname = %s", GetSQLValueString($Paramclientname_WADAclients_det, "text"));
$WADAclients_det = mysql_query($query_WADAclients_det, $authen) or die(mysql_error());
$row_WADAclients_det = mysql_fetch_assoc($WADAclients_det);
$totalRows_WADAclients_det = mysql_num_rows($WADAclients_det);?>
Thanks for the support
Sudeep K Pavithran
CraigRBeta Tester
could you possibly add the two pages to a zip file and upload it ?
i can then take a proper look.
Regards
Insert & Update PHP files
Hi
Please find attached zip file for both insert & update php files.
Many Thanks
Sudeep K Pavithran
CraigRBeta Tester
I looked at the insert page, and there is no recordset there.
the following lines...
should have code which, when the insert button is pressed, will insert the correct data from the form into the recordset fields.
In Dreamweaver, take a look at the 'insert record' server behavior if it is there, to set these values.
if it isn't there, and you are unfamiliar with php, I recommend you try going through the wizard again
Update & Delete issue
Hi Craig,
With your help, I got rid of the errors and "Insert" is working fine now... But record is not getting updated & deleted in their respective pages.
I saw in another thread that the space in the variable value is the problem. As it converts it into %xx.. Please tell me how do I get rid of this..?
Thanks & Regards,
Sudeep K Pavithran
CraigRBeta Tester
on the update page, try changing the comparison string to "=" and see if it works.
It may be that you are trying to update the recordset where no criteria are met, so nothing will be updated.
For the delete page, post a copy of the page to the forum.
Hope this helps
Data Assist problems solved!
Hi Craig,
All the issues got resolved. Thanks for your time & help!..
It was just because of my inexperience in php.
I must say, Data Assist is really a good tool for users like me.
Thanks once again!
Regards,
Sudeep K Pavithran
