In Css menu write how do you specify target blank
Thread begun 12/24/2009 9:23 pm by GaryDCoxDFW | Last modified 12/28/2009 12:18 pm by Dani Chankhour | 3119 views | 3 replies |
GaryDCoxDFW
Need link to open target up in own window.
gruant2000381341
use target="_blank"
here's an example from a plain text link with that applied
<p><a href="officers.html" target="_blank">click here</a></p>
GaryDCoxDFW
need a real world example on this
At present I know this is wrong:
/Fax Forms PDF/DAC Commercial Construction.pdf="_blank"
I am trying to under how it is entered in relationship to your software, I can hard code it, but I need to know how to do this in menu writer as in the attachment, so I can do my usual work. All I am trying to understand is if I want to add _blank what is the method and the sintax ; or = or , or what is ther a space just the general rules if I want to apply a tag in CSS menu writer. I may be making it harder than it is because I have been hard coding it for years, but once I get it I can do so great things with it, on this one the light bulbe has not came on yet,so if you can show me what it should say it should come on. Thanks.
Dani Chankhour
Currently the Menu Writer wizard does not give you the functionality to add the target attribute to your menu.
