Parse Error?
Thread begun 12/26/2009 12:02 pm by elevy388997 | Last modified 12/29/2009 3:56 pm by Eric Mittman | 6100 views | 12 replies |
elevy388997Beta Tester
Parse Error?
I am getting this error and have no clue how to get this form working:
Parse error: syntax error, unexpected ')' in C:\Inetpub\vhosts\secure.embforum.com\httpdocs\Contactus.php on line 123
Line 122 - 125:
if (ValidatedField('contactus','contactus')) {
if () {
if (!(false)) {
If you need more information, please let me know as I don't really know what is causing this.
neilo
It is expecting some conditions to appear before the second (closing) bracket of the 'if' statement.
The 'out-of-the-box' code that would normally be here for the contactus.php form page is:
if (ValidatedField("contact","contact")) {
if ((strpos((",".ValidatedField("contact","contact").","), "," . "5" . ",") !== false || "5" == "")) {
if (!(false)) {
Office Guy-172461
Have a look here:
6.php
I have no idea what you are trying to accomplish with those lines.
Ok I got the form to show up and it is able to be filled out correctly (dynamic items work), but when you click submit, it just resets the form and doesn't do anything.
And it is a submit button, not a reset button. I am using the DigitalGoodsCheckout form in this case.
So I figured I would start over and see if I could figure it out and 2 things are happening.
The first time I used the normal smtp settings for the mail server in universal email, and everything would work out fine until you hit the submit button. It would just "flash" the internet page quickly then all the text would be gone, so it was empty text fields again, and no email would be sent and it wouldn't go to the "thankyou.php" page.
The second time I figured I needed to authenticate the mail server so I choose the PEAR option in universal email. Now when you hit submit it gives this :
Warning: waue_sendmail(Mail.php) [function.waue-sendmail]: failed to open stream: No such file or directory in C:\Inetpub\vhosts\secure.embforum.com\httpdocs\WA_Universal_Email\PEAR_Mail_using_SMTP_PHP.php on line 115
Fatal error: waue_sendmail() [function.require]: Failed opening required 'Mail.php' (include_path='.;./includes;./pear') in C:\Inetpub\vhosts\secure.embforum.com\httpdocs\WA_Universal_Email\PEAR_Mail_using_SMTP_PHP.php on line 115
So I went to that file and this is line 111-123:
function WAUE_SendMail($mailObj,$mailAttachments,$mailBCC,$mailCC,$mailTo,$mailImportance,$mailFrom,$mailSubject,$mailBody) {
if (strpos($mailTo,"@") < 0 || sizeof($mailObj->recipients) == 0) {
return;
require_once($mailObj->PearPath."Mail.php");
$paramArray = array();
$headerArray = array();
$headerArray["MIME-Version"] = "1.0";
$fromArray = WA_getEmailArray($mailFrom);
$mailFrom = $fromArray[0][1];
if ($fromArray[0][0] != "") {
$mailFrom = $fromArray[0][0]." <".$fromArray[0][1].">";
Any solutions? I tried the help files and search function. I did notice though with the first method, there was a "Mail.php" and for the second one it doesn't create it.
I couldn't figure out what was going on so I deleted the local and remote files and tried the contact form solution pack...and it worked. But I would like to use the FB since I like it much better and should have been able to make a form just like the CFSP. I am going to try and redo the form various ways and post my results.
Ok now I am getting a new error:
Error generating form:
TypeError: this.ThemeArray has no properties
then I click ok and get this:
While executing timer in WA_SiteTools_Progress.htm, the following Javascript error occurred:
At line 215 of "C:\Program Files\Adobe\Adobe Dreamweaver CS4\Configuration\Floaters\WA_Progress\WA_ProcessingObjects.js": wa.generate.themeArray has no properties.
Office Guy-172461
Try step 1:
146/
Thank You, I cleared the cache reinstalled the extensions, cleared it again, and it is working.
I have a new question.
When I am adding additional fields to the form, I have it as two separate "sets" on the same "line". So it should have the two fields on the same line. In the form preview it DOES but when it goes live, it DOESN'T. I tried changing the form width via "Edit Design", and it gets wider but it still puts the two fields on top of each other.
You should edit the form with the edit contents and select the set you want to be on the same line, make sure that you have the box checked that says 'continue on same line as group above'. This should ensure that you have the input on the same line rather that on it's own.
When you go to the sets, there is no continue on same line as above. In the content editor it shows up correctly (1.gif), but when I upload it live, it turns out differently (2.gif). See attachments.
