Charges and previous/next buttons
Thread begun 12/31/2009 9:52 pm by denise234045 | Last modified 1/05/2010 11:26 am by Eric Mittman | 2105 views | 3 replies |
denise234045
Just can't keep away....
Two things I'd like to accomplish. I am using flat rate shipping that I set up in the ecart object panel under the Charges section (not from the shipping tab) It works fine, except in the admin order_details.php there isn't a row for 'charges' and I can't figure out how to add...
I tried...
$<?php echo(number_format($row_WADAorders['OrderCharges'],2)); ?>
and a few other things with no luck.
Next - I'd like to add 'previous' and 'next' buttons to the product detail pages so that users can scroll through product items one at a time.
Thx!!
The way that PowerStore is setup you will not record the charges that are created under that tab. Only the tax and shipping will be recorded for the order. If you would like to record your charges for the order you will need to start by adding in a column to your orders table to hold the charges. Once you have done this you would need to update the store order summary on both of the confirm pages. In these server behaviors you would need to bind the total charges to this new charges column.
Once you are recording the value in the db you will need to update the admin order details page by adding in your reference to the newly crafted column in your orders table. If you name your new column OrderCharges then you can use the reference that you have here for that.
denise234045
Thank you.
How about adding Previous and Next buttons to the product detail pages?
A link to a details page is the same for all products, it just makes use of an id in the link.
You could add in previous and next buttons that have links to other products. To get the id for the new product though you would need to add a recordsets to the page to pull the 'previous' and 'next' products.
