Charts from recordsets
Thread begun 1/01/2010 1:10 pm by shelpat393784 | Last modified 2/18/2010 2:05 pm by Eric Mittman | 6610 views | 10 replies |
shelpat393784
Is there a method that can crate a chart from a recordset that has 2 dynamic parms from dropdown lists? I am able to show the results in a table. Could the same recordset be used for a graph?
The recordsets that are used in the DWC are crafted from within the wizard. In here you can craft recordset to be based on a parameter like a URL parameter. To make this work with your chart though you would need to have the page submitted with the selecting of the second value from your dropdowns. You can then have that value post to the page and have the chart be filtered on that value.
shelpat393784
I am currently submitting(and seeing the resulting table) after both parameters are chosen. When I use the resordset in the wizard will it show the columns so I can select the contents for the chart?
shelpat393784
Recordsets with parms
You can select the columns for which the data comes from within the interface, you can also select the column that you filter the information on. I'm including a screen shot of the page in the wizard so that you have an idea of what you can do in this interface.
shelpat393784
Dynamic selection in in chart has no display.
I bought the product. I put in the connection,database table, xlabel, y label .
It is showing the data elements in the table. I put in one of the data elements in the filter and url parameter in the dropdown. After pressing F12 and submiting the query I get no chart at all. I do get my table filled with data. I am selecting two partms one for location and one for indicator. I only see space for one parm on the data screen.
If I take the filter off I still get no chart. When I am in design view I see a square and an box with an F(for flash).
Please help
Thank you.
I have opened a ticket for you on this issue so that we can exchange some files. To update your ticket please login to WebAssist.com and visit your support history. Please post back with the requested files in a zip archive.
shelpat393784
Charts From Recordsets not resolved
This issues still has not been resolved. I thought it would be a simple issue to create a graph with 2 passed parameters.
Are you still working on this through your ticket? What is the number? I can check on things to see where it is at.
shelpat393784
Technical Support Ticket # 111941
I have had no contact in 10 days.
