Is this malicious or an error?
Thread begun 12/18/2024 9:49 am by simon167250 | Last modified 12/21/2024 8:11 am by Patrice | 407 views | 1 replies |
simon167250
I'm getting errors showing in the log like the ones below:
PHP Fatal error: Uncaught mysqli_sql_exception: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'ANDPROCEDURE/**/ANALYSE(EXTRACTVALUE(8971,CONCAT(0x70324172,(SELECT/**/(ELT(2...' at line 11 in /home/mwccco/public_html/mwcc/reports.php:54
PHP Fatal error: Uncaught mysqli_sql_exception: You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near 'ORPROCEDURE/**/ANALYSE(EXTRACTVALUE(8971,CONCAT(0x5465564e,(SELECT/**/(ELT(28...' at line 11 in /home/mwccco/public_html/mwcc/reports.php:54
I can't replicate these through the 'normal' use of the site that I built using Webassist's MySQli extension.
Is this someone messing with a very bland cricket website?!
Many thanks in advance,
Simon
PatriceWebAssist
To get the best responses from fellow WA users, please list the page where the error happens.
