Menu links to wrong place
Thread begun 1/26/2010 10:00 am by Infotraveler | Last modified 1/26/2010 2:06 pm by neilo | 2338 views | 4 replies |
Infotraveler
I think something has gotten screwed up. I used the CSS MenuWriter to attempt to add a menu item. Then the site started giving errors about not finding files. I then found out through the forum that CSS MenuWriter is NOT compatible with PowerStore 2 because some manual programming has been added in to the menu files. So I replaced all the CSSMenuWriter directory/ files with the original powerstore files and the web site began to work again. But now I can't seem to solve the menus pointing to the correct subdirectory. Is there more damage control necessary ?
The issue is with the Powerstore 2 menus pointing to the wrong directory. I have entered all the information into the Globals file and it used to work correctly. I changed the name of the subdirectory and also changed the information in the Globals file (as shown). Now the menus point to the top of the html root ( and not to the /pvartstudio/ subdirectory. Notice that the photo links go to the correct directory.
The URL for the developing store is [removed because issue has been solved and wish to remove from active search engines indexing]
Here is a copy of the first part of the Globals file:
$WAGLOBAL_Root_URL ="[removed to keep out of search engine indexes"
$WAGLOBAL_Site_Name = "Store";
$WAGLOBAL_Address = "800 S. ";
$WAGLOBAL_City = "Red";
$WAGLOBAL_State = "CA";
$WAGLOBAL_Zip = "90";
$WAGLOBAL_Country = "US";
$WAGLOBAL_GoogleAPIKey = "REDACTED";
$WAGLOBAL_localRoot = "/";
$WAGLOBAL_remoteRoot = "/pv/";
Thanks,
Steve
neilo
Try adding pvartstudio to your localRoot:
$WAGLOBAL_localRoot = "/pvartstudio/";
$WAGLOBAL_remoteRoot = "/pvartstudio/";
That seemed to make the difference when I had the store set up in a sub-folder, - though I'm not sure I understand why, I thought the remoteRoot took care of that.
Edit: This from the menu.php file:
$WA_localRoot = "" .$WAGLOBAL_localRoot ."";
$WA_remoteRoot = "" .$WAGLOBAL_remoteRoot. "";
$WA_curURL = strtolower((isset($_SERVER["PHP_SELF"]))?$_SERVER["PHP_SELF"]:"");
$assumedRoot = $WA_remoteRoot;
if (strpos($WA_curURL,strtolower($WA_localRoot)) === 0 && (strlen($WA_localRoot) >= strlen($WA_remoteRoot) || strpos($WA_curURL,strtolower($WA_localRoot)) === 0)) {
  $assumedRoot = $WA_localRoot;
So adding 'pvartstudio' to the WAGLOBAL_localRoot should help (?)
Infotraveler
Thank you, it worked !
Nelio,
Thank you for the suggestion. It Worked ! One wouldn't expect to also have to set the localRoot but I guess so. I wonder why ? Maybe the WebAssit programmers can check this a let us know why.
Thanks again.
Steve
Dani Chankhour
The way the local and the remote url work is, if the local root url exists then it uses that, and if it does not exists then it uses the remote url. in your case the local url was set to "/" which did exists because it is the root. For example, you can trying putting an invalid path for the local root "/invalid" and then the remote url would be used.
neilo
Hi Dani,
Thanks for the info.
