Sorting product and seach result
Thread begun 1/27/2010 5:23 am by tolushayoo193471 | Last modified 2/01/2010 6:07 pm by Eric Mittman | 3302 views | 9 replies |
tolushayoo193471
Hi
1) I will like my product page to show recent products that I've just being added to the database instead of being the last. I want it to show first. please help.
2) And another problem am having is that if i search for a particular product on my hompage the result will bring out all the products in the database instead of bringing out the one that was search for.
please help
The products will list on this page by ascending order based on the id, so the last added products will show last in the list. To update this you just need to go the the line that has the recordset on in and change the ASC at the end to be DESC.
Products_Results.php
end of line 155
change from this:
ProductID) = ProductID ORDER BY products.ProductName ASC";
to this:
ProductID) = ProductID ORDER BY products.ProductName DESC";
As for the search it should be using keyword searches using like, so if you type in the partial name of a product it should return any product that has that partial term in it. Do you have a link to your site and a test search value so we can see this?
tolushayoo193471
I've check the recordet and I cant seem to find these line
thanks
If you can post back with the product results page I can show you where to make this edit.
As for the search what should the result be of the search term you posted? I can see that there are hundreds of results when I use that search string.
As a simple test of the search I used the word snail and got back 3 products with the word snail in them. I then searched for moses and got 4 results. If I search for moses snail I get back six results (one of the items fits both searches). So the search is using an or comparison as the space separator. Would you like it to use 'AND' for this rather than 'OR' and ensure that all of the terms entered match?
tolushayoo193471
please find he attached
thanks
I had added the order by clause to the page myself and forgot this was not a part of the default file. I'm including an updated copy of this page for you. It should list the products by the id in descending order, so the last products added should be at the top of the list.
As for the search what do you think about this? Would you like to change it to have to match all of the search terms or is having it find results for any search terms ok?
tolushayoo193471
Thank you very much. I like to change it to have to match all of the search terms but i dont know how
In the products results page on line 46 is the line that controls how the search terms are treated. Currently the AND separator is ", " and the OR separator is just a space " ". So if you have more than one work separated by just a space then it will use or and find any matches for any of the terms.
You can change this around so that a dash is the separator for the OR by making it like this:
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_GET["S_ProductName"]))?$_GET["S_ProductName"]:"")  ."","AND","Includes",",%20","-","%22","%22",0);
This will make it search for the entire string in the product name.
So if you want to have it combine the terms with an explicit or you would separate the words by with a - rather than a space (word1-word2), if you want to explicitly use and you would use a comma space like this (word1, word2).
tolushayoo193471
thank you for your help. God bless
Your welcome, let us know if you have any further questions or if you encounter any problems.
