Insert Multiple Records Doesn't INSERT!!
Thread begun 1/27/2010 12:22 pm by scott399397 | Last modified 1/28/2010 12:23 pm by Dani Chankhour | 2426 views | 3 replies |
scott399397
When I attempt to Insert Multiple Records from a page, everything appears to work, but nothing gets put into the access database. Using Dreamweaver 8, DataAssist 2.0.6, Access 2002. I've included the .asp code in the attached file... Any help would be greatly appeaciated!
Thanks,
Scott
Dani Chankhour
Looking at your page, i see that you have 3 forms, only the second form have a repeat selection, but the problem is you have your submit button under the third form, so when you are submitting the form, you are actually submitting the third form only.
You will need to add your submit button to your second form since that is the form that is being used with the multiple insert.
scott399397
What Next?
Then how do I include all the data on the page without repeating unwanted areas? When I put everything on one form, the server behavior repeats even the areas not designated as 'Repeat"... I also don't want 15 'Submit' Buttons!
Thanks,
Scott
Dani Chankhour
You should not apply the repeat selection server behavior on the entire form, you should only apply it on the fields that you want to be repeated, so at the end you should have one form, with some part repeat and some part not repeated and one submit button. For example:
<form>
<input type="text" >
Repeated {
<input type="checkbox">
<input type submit>
And then based on what you would like to happen, you could either use the multiple insert server behavior by itself, or you could use it with a combination with the single insert server behavior. This really depends on how you want the data stored in your database.
