Sort order for options
Thread begun 1/28/2010 6:27 pm by jaa397769 | Last modified 2/28/2011 10:17 am by ripair417048 | 6082 views | 13 replies |
jaa397769
Please help, when I create a product for my online store, and then assign the add/option
Size: and then give the variables
xs
s
m
l
xl
It is sorting it by ascending so it comes out
xs "only because I assign it as default"
then
l
m
s
xl
I know this is how the database is seeing it, and I only see the option in mysql for
Ascending, Descending or None. When I selected NONE for the sort option, I still get an alphabetical sort. Is there a way for me to have the sort work so that I would have the drop down look like this always
XS
S
M
L
XL
Thank you very much.
Dani Chankhour
On your product Detail page look for this line of code:
$AddToWhere." ORDER BY OptionName" and change it to:
$AddToWhere." "
This will order the options based on order your entered the options which will give you the results you are looking for.
jaa397769
That doesnt work
This is not the problem, After I add the item to my database when I add the options for the drop downs for size or color it is sorting alphabetically. I need to be able to sort in the order I place it in the option fields. Unless you told me the wrong page to edit, I edited that page and the code started at line 429. But I still got the same results.
Dani Chankhour
Sorry, i might have misread your post.
Currently the only way to sort would be alphabetically, if you want to sort by the order you enter the options, then we need to add another column to your optiongroups table (optiongroupsdate) and set the type to timestamp and set the default value to "CURRENT_TIMESTAMP" and then we can change the order to order by optiongroupsdate at line 429.
Dani Chankhour
It is actually the options table that you need to add the column to, not the optiongroups table.
jaa397769
do i have to do this in
Myphpadmin for sql. If so do you have any documentation on how to do it? Or is it as simple as adding a column and giving it the attributes you said to.
Also wont I need some code written for my Product_Display.php page?
Dani Chankhour
We don't have any documentation on how to add a column to your database but it should be straightforward. In phpmyadmin, click on the options table and at the bottom you should see where it says add and at then end click the Go button and then type the name of the column, select time stamp for the type and select the current timestamp check box under the default value and click save.
Le me know if you have any questions about these steps.
jaa397769
Ive created the table
I am still getting the same results.
This is what my recordset reads now, what should it read
SELECT Group_Concat(Concat(OptionGroupName,': ',OptionName)ORDER BY options.OptionGroupID, options.OptionID SEPARATOR ',\\r\\n') AS CartOptions
FROM options INNER JOIN productoptions ON productoptions.OptionID = options.OptionID INNER JOIN optiongroups ON optiongroups.OptionGroupID = options.OptionGroupID
Jimmy Wu
The ORDER BY part of the sql statement should be at the end of the query, not in the middle. Give that a try to see if it'll work.
jaa397769
Order By
Will this change the way the option add ons lay out in the web page?
Also I created that table you told me to and it's collecting the time stamps, but I still have the same problem when the drop down menu is pressed, its all out of order.
Can you show me how that statement should read?
also I just tried in the backend admin add options section to put them in the list as such
1. Small
2. Medium
3. Large
4. X Large
5. XX Large
in the backend preview they listed correctly on the drop down, but on the live site it listed like this
3. Large
1. Small
4. X Large
5. XX Large
2. Medium
It just doesnt make sense. could you please tell me whats going on and why this is happening.
